2015 tri glide emergency brake
never posted before but have a question
my 2015 tri glide e brake goes to the ground and needs adjusting...can i do this myself or do i need to take to the dealer...and if i can do it are there instructions anywhere that explain how to do this
emergency
buy the trike supplement service manual. Explains in detail, easy to do manual will cost less than the labour and it needs adjusting often
Slide the long rubber protective boot back. It is a simple threaded bolt and jam nut arrangement. Pedal should be adjusted (per the trike supplement manual) so the 4th click down holds. This cable does stretch a lot when new. Jamming the pedal down contributes to stretching. My 2014 has 26k miles and between the Dealer and myself, it has been adjusted about 6 times. I will soon be replacing all brake pads and adjusting it back out!!!
Bob :D
It actually explains the procedure in the owner's manual. Takes two different size open end wrenches. One is metric btw, the other is SAE. Still haven't figured that one out.
dhinzman1
