2010 Kawasaki VN900 Lehman Storm Turn Signals
stancotreau
5+ Posts
Sep 12, 2012
16
24
Billerica, MA
Stan
Hello all, I've never had an issue with my directionals until today. My bike is a 2010 Kawasaki VN900 Trike with a Lehman Storm kit. The previous owner installed a NAMZ hot Box, which automatically cancels the directionals. Today I noticed the Right tailings were not blinking (front was blinking fine). When I turn on the left directionals, the right one also blinks, but it is very dim. Has anyone had this issue? Any ideas as to what is causing this?
In many cases, odd electrical occurrences happen usually because of a problem with a ground somewhere. Sometimes it's a loose ground wire, a corroded mounting point, or a connector with ground wire that has overheated for some reason. I would see if you can get a diagram of the turn signal circuit(s) and also check the grounding of that NAMZ device.
thank you!
dhinzman1
