2004 CSC Escapade Packing Bearings?
Apr 26, 2013
162
209
Clio, MI
Ray
Hi, I was packing my wheel bearings today on my 2004 CSC Escapade trailer today. Upon pulling the nuts off I noticed that the two washers that go behind the spindle nut was different in orientation than the other. For those of you that are familiar with the CSC Escapade I have a question; Could you tell me if the larger washer goes against the bearing with the smaller washer being behind the nut? I would think that the orientation would be as follows; bearing > large washer > small washer > spindle nut & pin. Please let me know for sure for those of you that's been there and done that....... I would sincerely appreciate it. Ray ;)
Ray, did you buy that trailer new?
Reason I ask is I dunno if I ever saw 2 thrust washers on a spindle nut
Remove lug nuts and wheel a
ssembly. Remove the cotter pin, adjusting
nut (castle nut) and washer from the wheel spindle.
This is a typical removal for most bearings I have seen
Yes I purchased new and I must have reversed them on one side last time I did a bearing pack. Thanks, Ray
Roger71!!
