hardheaded
300+ Posts
anyone seeing this problem on their tri-glide ? mine have failed at 3500 miles. not very much quality here and i'm very disappointed in this bike so far.
What year and do you have pics?
Nuc
i know what you mean about the new ones , but i have pieces of rubber coming out from under the cap and you can look right though what's left of them.I'm interested in the same info also.
I have put over 100,000 hard miles on some TG's and never had a failed (or excessively worn) swingarm bushing.
I have seen them look like they were bad...not centered....but the look like that new.
maybe if my kid stop by i can get him to take some pic's and post them. have you looked under that cap on your trikes ? i know you out some big miles on your rides.I'm interested in the same info also.
maybe if my kid stops by i can get him to take some pic's and post them. have you looked under that cap on your trikes ? i know you out some big miles on your rides.I'm interested in the same info also.
i can watch the entire left side of the pivotshaft move up and down if i jack the bike up. the right doesn't move. when i jack it up the pivot shaft lines up with where it should be all the time. once you set the weight of the bike on it it moves way forward and up. i'm sure it's putting a strain on the other motor mounts. something going on with it for sure. i know all those rubber pieces should not be in there.
i placed the jack under the left side of the frame and the right just to see how much movement is there. lots more on the left side. the dealer called early this morning and asked if i would like to see what they found, i jumped right in the truck and went down there. swingarm pivot shaft was loose. they are going to install new bushing on both sides. hope to have it back by the wekend. they are looking at all the trike on the lot and showroom floor right now and are seeing the same issue on some of them. at least with a new bike they could just retorque the pivot shaft, at least that's what they told me. it's not over till it's over though.Where are you placing your jack contact point when you jack it up?
crazy this is happening to some and not all.
If it was happening to all then there would be a recall... Sometimes things just happen!
Just like reverse motors , Some fail...
And many don't...Sh*t just happens sometimes' even to nice people..:Shrug:
All this talk about the swing arm bushing, On this forum and other forum's finally got me to bend down to look at mine...43 thousand miles 2011 Tri=Glide....Just like i did a year or two ago when this came up on Forums...
And what i noticed today.... Was just what i noticed a year ago... A little wear on the outside of the bushings..[Not enough to worry about] And just like a year ago the center nut was off center......So in my case...Only ''Mine''...I consider it normal...:Shrug:
was it painfull when you pooped those plugs out ? sorry, couldn't help myself .I have a 17 so this thread peaked my interest so I pooped the plugs off and looked .At 5300 miles clean as new with no rubber or steel shavings.I will try to keep an eye on it every 1000 miles.
