Using reverse as a parking brake
Jan 5, 2014
68
3
Jackson, MS, USA
The guy I bought my trike from said to use reverse as a parking brake. On one of the older threads I was reading today someone said never do this. It's too much strain on the reverse gear. Another guy said he used a strip of Velcro around his hand brake when he parked. Really? If it's not a good idea to use reverse when parking, what do you do? Is the velcro thing for real?
First Gear or Velcro- I used both depending on the incline and my nervousness on the grade. Never use the reverse gear. They are right, to much strain on such a small gear and if it breaks; BIG dollars to fix.
Ride Safe
Nuc
<div class="bbcode_quote">
<div class="quote_container">
<div class="bbcode_postedby">
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>bohomus</strong>
<a href="showthread.php?p=212647#post212647" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">The guy I bought my trike from said to use reverse as a parking brake. On one of the older threads I was reading today someone said never do this. It's too much strain on the reverse gear. Another guy said he used a strip of Velcro around his hand brake when he parked. Really? If it's not a good idea to use reverse when parking, what do you do? Is the velcro thing for real?</div>
</div>
</div>
</div>That was probably me, and yes it works. BUT, I only use it when I'm making a very short stop and don't want to kill the engine and sometimes as a bit of insurance on steep grades. Most times it's used when I'm letting my wife get off before pulling into the garage. Like others have suggested, first gear.
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>nucseal</strong>
<a href="showthread.php?p=212663#post212663" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">First Gear or Velcro- I used both depending on the incline and my nervousness on the grade. Never use the reverse gear. They are right, to much strain on such a small gear and if it breaks; BIG dollars to fix.<br />
<br />
Ride Safe <br />
Nuc</div>
</div>
</div>
</div>I also use first gear and the Velcro. Has worked well so far.
I made a small aluminum wedge that I hang from the front brake perch. I just pull back on the brake lever and slip the wedge into the opening of the lever. Works great....<br />
<br />
Terry
While there undoubtedly are good ways to immobilize the trike, the best reason I was given for parking it in reverse is that the key is needed to alter that, and only you have the key. <br />
<br />
In one's absence, Velcro can be unwound, wedges removed etc.
Although I do fall to the temptation to use reverse as a parking brake I only do so on a level surface. If you put very much pressure on the Honda reverse it will break and the repair to the starter is quite expensive. I use 1st gear and/or the curb otherwise.
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>Calgary</strong>
<a href="showthread.php?p=212692#post212692" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">While there undoubtedly are good ways to immobilize the trike, the best reason I was given for parking it in reverse is that the key is needed to alter that, and only you have the key. <br />
<br />
In one's absence, Velcro can be unwound, wedges removed etc.</div>
</div>
</div>
</div>Besides the possible damage folks have talked about there is the chance you could have the reverse become stuck requiring you to push back on the trike with hopes it will disengage. IMO the reverse is nice when the Goldwing is 2 wheels but not of much use on 3, I've taken to selective parking and I use a velcro strap if I think I need a parking brake. If I'm concerned about theft protection I add a disk lock to the front rotor.
I try not to use my reverse as much as possible, but there are times that it comes in very handy. With Wing Boards installed, you can't put your feet down and duck-walk the trike backwards. Either you get off and push her back or use reverse. So far, my reverse has worked perfectly.
I use my rear parking brake, 1st gear and lock my forks for security.
A friend of mine broke the small gear in tran used for rev. cost was $1,000 to fix. The entire motor is removed. The case is split the tranny pulled apart. The gear brakes and falls into the oil pan. Not sure how the. 1800 does Rev but the 1500 is best not used at all. I used mine 12 times in 14 years 67,000 miles . Selective parking and 1 st gear.
Thanks all. Looks like 1st gear and velcro hand brake it is. On the hand brake, am I understanding that it's for a short time only. Does it hurt to leave to on like over night or for several hours?
I only use reverse as a security measure. At home, my parking space is slightly sloped, so I back in, over a 2” X 4”, let the trike roll against the 2” X 4”, then put it in reverse before shutting down. Nobody is going to move the trike, unless they pick up the back tires. If they want it that bad, they will get it, in reverse or not. When I"m ready for the next drive, I can start up my ride, and let it idle for a few minutes. I never leave the trike in reverse, when under pressure.
Out & about, I use first gear. If quite steep, then the Velcro strap comes out to go around the front brake lever. The strap is permanently on my right handlebar – slides down in the handlebar tunnel and is not even noticeable. On a group ride last year, had to stop on quite a steep section of road (because of an accident) and put it in first to try to hold it stopped, and it turned the engine over, and would not hold. I ended up putting the front tire against the embankment on the shoulder. (This is before I got the Velcro strap.)
Rich, you’re lucky on your parking brake. Even when adjusted properly and pulled on hard, I can push the trike by hand. As far as I’m concerned, it is a worthless accessory.
DO NOT use reverse on an 1800 as a parking brake. The reverse button is known to get stuck in the "on" position. It happens more in cold temps than hot temps. Rocking the trike back and forth will do nothing. The switch will need to be taken apart for cleaning or replacement. If the switch does get stuck, you can play with it and sometimes it will un-stick.
On another note, there is no "reverse gear" in the transmission to break. The transmission is in N and the starter motor is actually pushing the bike/trike in reverse.
I said not sure of the setup in an 1800. I know as a fact the 1500 has a gear and it can break. I believe the 1800 reverses the rotation of the starter and it hits a gear to back up. The starter by itself is not connected to the rear wheels. Stronger set up than 1500 but still not unbreakable or abusive to the battery or starter motor.. The starter on a wing should not be operated for more than 10 or 15 sec at a time.
I don't use reverse for a parking brake because I've heard that if your battery goes dead, then you're stuck in reverse and can't move the bike until you get a new battery or jump start. It can't even be towed.
I wonder about using velcros on the front brake lever. Would it bleed down eventually allowing the trike to roll? I've always been courious about this.
My dealer said use reverse and I do with the exception of on a hill .
I use my reverse all the time, but not as a brake. I've never even HEARD of anyone that had their reverse fail if they used it properly, and I've owned 8 Wings and 5 of them have had reverse.
Item number 5 PN 28162-MN5-000 in the picture is the revers gear, the diagram is the reverse gear parts for a GL1800.
Guys
Rather then start another thread maybe a short answer or 2 is appropriate here.
I use my reverse quite a bit actually.
Pulling the trike out of my garage in the morning and leaving work at night.
Question is this.
Am I going to prematurely wear out my starter by using the reverse gear daily??
Id say its running in use more then 10 seconds at a time.
As its actually pretty slow while in use is this putting a large strain on things??
I have a mechanical reverse but don't use it for a parking break. always use selective parking and 1st gear. the Velcro strap is a new idea to me . sounds like a good one too.
I don't use reverse when parking the bike.
Just out of the garage and backing away from my storefront.
I leave it whatever gear I happen to have stopped it in. Usually 3rd.
Ill give my legs some exercise on the good days from now on I guess.....
Thanks Wheels.
I use reverse as little as possible to save wear and tear. That said, I came across these:
http://www.amazon.com/dp/B000QA7ZIY...TF8&colid=25R5PSHVWNOL2&coliid=I2WW3EMUSICM99
I have one tied around front brake master cylinder and when I park, it gets stretched and wrapped around the front brake level. There's 12 to a package...I keep a few as spares, but in seven months, the original one has yet to fail.
The Captain's Curse be upon Ye huh?;)
No biggie my Friend. Just get one of those heat contraptions you use to style your Coif and give 'er the "Heater".
If that fails to lift the Hex, a 2 lb Attitude Adjuster will do the trick.
Won't solve the Issue but will definitely ease your frustration and tune your frame of mind if only temporarily ThumbUp
Good luck to you and hopefully the Cold MoJo isn't contagious :D
