All,
Basics; '93 GL1500 with a Motor Trike conversion.
Found out that the trike was never wired for trailer lights, even though it had a receiver on it and a hitch. I need to be able to tow the little Harbor Freight trailer with it. Trailer already wired up and has been behind the Shadow for a couple of years.
Bought a few things to get the project started.
Subharness kit with isolation relays in it.
5 Way to 4 Way adapter (compatible with LED lights on the trailer).
Round 4 Way plug (instead of flat-4).
My question is about the wiring routing. Where do I find the connectors that the subharness plugs into, and how should I route the wiring from that location to the underside of the Motor trike and back to the hitch?
In reading a little about the GL1500, it appears that the brake/tail/turn wiring connectors were under the top box, but that might not be true, after doing the M/T conversion.
On my Shadow, the rear wiring harness was under the seat and easily accessible.
Is the same true, for the GL1500?
Thanks, Allan
Thanks, Allan
