Tri Glide Rear Brakes.
Yes..some get more some get less..Not sure if you are going to replace them yourself.
but make sure you lube up the bushing/spacers as I have found them sticking when I have done mine in the past..Try EBC or lyndall for new pads..
I found that if the parking brake was adjusted correctly I would need rear pads every 7000 miles. So I unadjusted them and put lyndalls on, have 10000 on this set and they still look new. If I need the parking brake I just use a leather strap I carry and tie it around the front brake lever. Seems to work fine for me.
I have an 05 Lehman conversion with drum brakes on the rear, and 20K on the clock. The rear shoes will have to be replaced later in the season. I am surprised that the shoes have worn so much, but as the second owner, I am not sure how much braking the previous owner had to do, and how fast he would ride. I know he rode two up. Given the choice, I would rather change disc pads than drum brake shoes any day, so I guess you are lucky.
Yikes, loosening up my parking brake as we speak!!!:xzqxz:
I removed my parking brake the first year I owned it. I like you will use a Velcro strap wrapped around the front brake lever. I very seldom have to strap the front brake. I also went to Lyndall front and rear. I still have my 2 wheel braking habit where I use the front %80 and the rear %20.
Just remove that worthless parking brake. Then you never have to deal with it and the side effects it causes ever again.
Depending on the type of riding, freeway vs city and how hard you apply the brakes is going to play on how often you need brake pads. At the beginning of this riding season my dad had 37,000+ miles on his 09, in those miles he has only put 2 sets of rear brakes on and 1 set of fronts. The original rears still had life left on the pads when we changed them as did the original fronts. We changed both sets in favor of the Lyndal gold pads. His riding is a mix of city and freeway, he isn't a big rear brake peddle user, doesn't have a parking brake, well he does but it resides in the garage attic, and most of his stopping he knows ahead of time so he doesn't have to use a bunch of brake to stop.
Both of us use brakes pretty much the same, I have Lyndal front & rear pads on my 06 Ultra which have 27,000 miles on them and when I inspected them this winter I can put another 27,000 on them with ease.
My rear brakes on '10 TG were fast wearing also...until, HD replaced the whole parking brake mechanism. Installed home on LI, then correctly adjusted behind wheel by Tucson HD when in there for other things.
Ditto here! Velcro strap around the front brake lever if parked on a hill. I removed the parking brake and all its cables and springs at the first rear pad replacement. I think I get better mileage now.pepper HA HA
how do I get the pistons to back in on the rear calipers, pressure doesn't do it and there doesn't appear to be a place to screw the pistons back in the caliper. all help will be appreciated
Once you remove the caliper and parking brake bracket- turn the shaft that is has notches out all the way then push the caliper pistons back in. If you do not turn the notched shaft the pistons will not retract..
You will have to readjust the parking brake per the manual or remove the parking brake as some have done.
My new trike is coming next month is the parking brake no good to use
Just the fact that many have left the brake on & rode the trike for a while before they realized it. Results in wearing out the pads fast ! Causes glazing of the pads that aren't large enough anyway, so there is a high loss of rear braking in the rear.
Sometimes the brake isn't released all the way & the pads are held against the rotor without much pressure, but causes the same problems.
Many have just eliminated the park brake, & the worry it causes.
A wrap type of Velcro works fine & you can store it on the handlebars. To use just pull back the front brake lever, & Velcro in place. Along with the first gear engagement it will hold great.
:Trike1:
A follow up on my rear brake problem.
The Dealer replaced the pads and the rotors under warranty.
So now we will see how long these last.
Some things you can do that will help are, anticipate and begin slowing down some before you need to apply the brakes, use both front and rear brakes to stop with. Yesterday I was waiting to cross the street at a stop light when a group of about 6 trikes come to the light. More than half of them just used the rear brakes and never touched the fronts, I'll bet they replace pads often.
Terry corey
