Tri Front Wheels
NHBAGGER
400+ Posts
Jan 7, 2015
390
89
Barrington, NH
Richard
Posted this on another Forum with no results.
Does anyone know what the difference is between 09-13 and 14/15 front wheels? Some ads say they are the same whereas others break it down by years?
A TriGlide and an Ultra both use the same wheel,I would think. Can't imagine H-D producing a trike-only front wheel.
One thing I am sure of is that there is quite a bit of interchangeability. For example,between a 2013 wheel versus a 2014,wheels are the same as are the rotors. The only possible snag is ABS vs Non-ABS in which case the bearings can be swapped.
I'm pretty positive the front rotors were increased in diameter size in 2014 .... as the front calipers were also changed. P/N for front pads is definitely different for 2014/15 TriGlides. I just bought front pads so I am positive there is a difference.
Bob :Dorag:
The rotors are different on the 14-15 TriGlide so you are correct,Bob. The front wheels are the same,bike or trike though,and the bike rotors are also the same. So,if a 2011 TriGlide wanted to upgrade to the newer wheels,it would be an easy swap.
ledgin
