Grips
Dec 22, 2018
76
39
Fredricktown, MO
Ed
Is there anything I need to look out for on the throttle side? (2019 triglide)
Is it just separating the control, cutting the old grip off and sliding new on? With all the electronics on these new ones i'm Just a little intimated.
Thanks..
Thanks..
There is a video that shows how to change out your grips. You will need to loosen the handlebar control housings to slide your old grips off and install the new ones. If you look inside your new throttle grip you will see that it is geared in the bottom end. Takes around 15 to 30 minutes to change your grips out.
DuneRider
