Doc's Perfomance Tuning
Apr 4, 2015
22
4
Conroe, TX
After a lengthy discussion with my awesome wife, I will be setting up a appointment with Doc to add the TTS100 cam and TTS tuner to the trike. Even though Doc's Dyno can't handle a trike, he said he will be able to make the trike run like a new one. I trust Doc to tune the trike without a Dyno. The trike currently has a Screamin Race Tuner and Air Cleaner with V&H power duals. I'm experiencing mild popping on decel and feel something is not right with the tune on it now. I called a Harley dealer today that had a Dyno that can handle a trike and inquired if they a had a expert on the SERT and their response was any of our techs can do it. My response was ok, I'll call you back later to set up an appointment.......NOT
I'm looking opinions here and suggestions and any and all will be appreciated.
Not sure if this helps but there is a thread on Trike Dyno locations maybe theres one in your area?
There is one 3 hours away but I don't like the fact that there is no one person who operates the Dyno.
I think GMR Performance in Fort Worth now has a trike dyno or access to one. When I decide to have our trike dyno'd,that's who I trust to do the work.
A person that knows the TTS tuner can do a great job with the test ride learning functions of the TTS. That's how mine was tuned and it is great. Only thing is don't get the bragging dyno numbers. But who cares if it runs strong it's done.
Clint, you may want to give Steve at GMR a call, I stopped by his shop about a month ago to inquire about his access to a trike dyno based on a post you had made in I think the trike dyno sticky thread. Basically dyno jet had contacted steve about helping out a shop with Winpep8. The shop had a car dyno. The shop said steve could rent time on their dyno to dyno trikes. Steve while I was there couldn't recall the name of the shop. Steve called dynojet while I was there trying to run down the name of the shop to no avail. Dynojet sounded like the auto dyno wouldn't do a good job anyways because the load would be all wrong or something. If I understood steve correctly, he has mostly tuned the few trikes he's had using the TTS and its data gathering software.
Ken
Rice Lake Harley
Finally Rice Lake Harley in Wisconsin get a Dyno for trike:pepper: Its going to be an awesome summer think I might wait on front end mods and play with motor. It will draw to much attention if I stretch it out but humm the motor not so much might try s&s 557 cams and tuner
DuneRider
