DK LIFT
Apr 10, 2016
mtn home id
I had a 2009 tri- glide installed the lift kit, traded it in for a 2016 so i removed the lift kit. Tried to installing them on my 2016 can't get my axle down low enough too install them. Has anyone else ran into this?? Thanks
If you purchased a DK lift kit why not PM them direct from the site here. Get the best answer that way.
^^^They are excellent folks to help you out when you need it. They will answer questions about things even if you HAVEN'T bought from them. They are just that nice.
You must remove both sides at the same time, otherwise the rear will cock and the shock holes will not line up.
DuneRider
