Can I switch back to Dino oil?
Feb 25, 2012
20
Ontario, NY USA
dealer put in synthetic oil in the motor at the 1000 mile service. Made the top end noise worse. Can I just drain oil, replace filter, and go back to Dino oil? Or do I need to scavenge out every drop of the syn? Thanks
Synthetic oil is made from crude oil, too, so they blend nicely, Jimdog. I'm switching (our TG) from that over priced Syn 3 to Mobil 1 as we had great luck for the last 60,000 miles on our Ultra.
Phu Cat
Absolutely. You can switch back and forth every month if you want to. ThumbUp
Just make sure you change filters also - at recommended intervals.
Personnally I will never use dino oil - unless there is some reason I have to.
DuneRider
