Air Suspension Cover
May 25, 2013
39
Keokuk, Iowa
Michael
To air up the suspension on my 2015 trike, you have to remove the cover then attach your pump. Why not install a 12 inch air hose to the input and run it outside so the cover doesn't have to be taken off each time. Has anyone done this?
I check the air every few months, And it stays right where it was the last time I checked.
So I see no reason to Rube Goldberg the hose.. But that's just me' If you can rig something up and that will make it easier for you'' give it a shot..ThumbUp
There was one on EBay that mounted in the tour pac in the right rear corner that had a gauge with the Schroeder valve. I don't have the link anymore, but they also had a web site. Their bagger kit mounted on the license plate frame with a gauge also.
The dealer did this in my trike the last time I had it serviced.
The stem extension from Harley is just what I was looking for. Tks Tour Captain, your description of how you mounted it is what I had in mind. Dale
Thanks for all the info guys, just installed the Harley extension today, I check it once a week since everything is still new. Much better than pulling the side cover.
ledgin
