Weymouth England
Do you two know where I can buy reversing mirrors other than the ones I've already got on the handlebars. I've git limited movement on my neck and can't easily turn to see my back wheels when reversing.
Thought occurs to me
Many cars I work on have a blind spot mirror, round self adhesive convex mirror attached to outer lower corner of wing mirror.
Might be worth a trip to local automotive spares shop or Halfords
I love the blind side mirrors on my truck. They are part of mirror assembly but separate so don't block any of the view of regular mirrors. After putting a set of stick on ones on the Goldwing, I wasn't a fan. They ended up blocking parts of the mirror I needed as well as being so small, were kind of hard to use. Not really sure what the difference is but have seen some other forums recommending the Harley police mirrors as well as split vision mirrors. Maybe try searching those and see if you find something useful.
Split mirror is a great idea
Wonder if it is possible to replace the glass on the Harley
I'm not sure on replacing the actual glass but there seems to be quite a few choices over on Amazon. Here is just one example. I am in no way recommending this one, just showing it as an example. My recommendation if you do this is to check the reviews and only go with one that has over 4 stars.
VPZMT Rearview Mirrors https://a.co/d/fGvdHmT
DuneRider
