For the $400.- $500.they get to have them paint ready its well worth it , take it out of the crate scuff & paint, or for about $850. primed, painted ,clear coated & buffed take out of crate & install , by the time you buy sand paper ,filler ,primer, hardner , sealer, base coat ,clear coat, hardner,tape, buffing compound you got to have $350. in materials & 5 days of sucking up hazards waste , I find just have the manufacter paint It . & I have a body shopThese body's require a lot of sanding to smooth out for paint.I have spent the most time and work on sanding and prep work on the body,than the rest of the work I have done on the build.I have just a little more sanding before primer is applied,then I get to sand again for paint.My big compressor blew up so I am doing all the sanding by hand,all the while my air file board and DA sander are laying in my tool box.Did I mention I have been sanding a lot.
For the $400.- $500.they get to have them paint ready its well worth it , take it out of the crate scuff & paint, or for about $850. primed, painted ,clear coated & buffed take out of crate & install , by the time you buy sand paper ,filler ,primer, hardner , sealer, base coat ,clear coat, hardner,tape, buffing compound you got to have $350. in materials & 5 days of sucking up hazards waste , I find just have the manufacter paint It . & I have a body shop![]()
Yep, only a couple of factories still offer paint ready as an option anymore, Roadsmith quit doing so quite a while back, so its either full prep and paint or no prep and paint, that's the only two options.
