U can still turn them off and on. Its u just have the option to have
them on when on high or low beam if u want.
I have a switch that turns on / off the spot lights. i also installed LED's on my turn signals that stay on in white and turn yellow when you use the turn signal.
That is pretty cool, how did you do that? Is it just different bulbs?
Yes, very simple plug and play. Replacement bulbs that fit inside the turn signal light housing. It's a kit I got at the HD dealer. The LED bulbs are in a circle (ring) on a disk that fit inside the light. When on they are White, when in turn signal mode they turn Yellow. $79.00 for both lights. They are Very Bright
Sorry :blush: I thought you meant you had them program your bike so the auxiliary lights would be on all of the time. In stock configuration the auxiliary lights will only work in low beam, and will turn off when you toggle into the high beam. I guess it might be kind of nice to be able to have both the high beam and the auxiliary lights on while riding through the twisties on a lonely road late at night.
