Falken tires
Jul 27, 2012
4
Lanett,Al.,USA
OK, guys and gals. Who has the Falken tire on there trike?
I called RoadSmith and they said that this is the tire brand that they are now using.
P205/65r16 is what the numbers are for a Gl 1800.Those that use this tire can you let me know how its doing for you. Is it quite,how are the side walls doing,how much air are you putting in the tire? What are all the numbers and letters on the tire. RoadSmith said this is a aqua tire they use.
So far this is what I have found on the internet on the Falken tire : Sincera Touring Sn211 205/65r 16 94 Sl. :confused:
OK I don't have a Goldwing but I have a Stallion and put Falken tires on it. I love then, they are quite and handle the road great. Sorry I can't help on the size you need but I think you will like the tire.
Dave that is not the Falken tire I have on my 2015 HTS1800. It is a Falken and the size is the same but it's a 95V M&S. It is a Ziex ZE950 All Season rated at 1521 pounds load and 149 mph. Here is a photo of the tread. Is Roadsmith telling you they are now using the SN211? If not then I'd suggest you give them a call. If they are then they have changed in the past year.
I did a little research on the two tires. Looks like the Sincera it a bit softer ride and a little harder compound. Longer live but less traction dry/wet/and snow. :xszpv: :xszpv:
DuneRider
